I've lost it and can't find it.
RE: I've lost it and can't find it.
Here's a writeup on how to do it: http://www.matthewsvolvosite.com/200...-volvo-s80-t6/
Thanks for the help. Just so I know I am doing this right, I need to remove the following pipe (highlighted in neon blue) in the following picture and then I just have to feel around the ETM (highlighted in neon green) for the 4 bolts and undo? I suspect the big bolt there on the neon green part of the picture is the first bolt? If this is correct, fantastic. I will do try and do it tomorrow or if not enough time the weekend then.
So I do not need to remove that pipe. Do I need to remove anything else except for the plug that goes into the ETM? Is it best to disconnect the battery negative? What if I didn't? The links I have seen describe sorta of what you need to do to get it out, but nothing in great detail. Also will I need a gasket once I remove the ETM?
I would disconnect the battery because you are working really close to the starter positive wire. You don't want to short to ground with the throttle body taking it out.
Yes you will need a new gasket.
If the ETM has never been removed you might need to take the starter to block bracket off. The wire from the ETM runs behind the bracket.
The ETM has been removed before as mine has a yellow sticker on it, meaning it's been changed over. Any idea what the gasket is called (i.e. ETM gasket)? Or do you have the part number that I will need to get another gasket for the ETM from the dealership?
Brennan.Messick
09-19-2011 03:06 PM
spankey
07-17-2010 09:35 AM
koster
10-11-2009 08:19 AM
