PCV System
Old Aug 1, 2013 | 05:34 AM
majorcode's Avatar
Default PCV System
Hi guys,
Instead of changing the PCV system, can I simply disconnect the lines or let the oil dip stick bit open to let the pressure out? is there any harmful effect on over all performance of the engine ?
Or I have to change the whole system and spend 300 USD
Old Aug 1, 2013 | 08:36 AM
No. It's a "Positive Crankcase Ventilation" system. It is designed to help the engine compression chambers work properly. Taking it apart can cause motor damage.
Old Aug 1, 2013 | 09:51 AM
ES6T's Avatar
That will relieve the pressure, but sometimes it can cause air to be drawn in and set codes for the MAF and fuel trim.
Old Jun 22, 2014 | 01:55 PM
divinedavis's Avatar
Just replace the oil catch tank.
MikeySq
Aug 10, 2021 09:52 AM
xjflexer
Jun 16, 2012 11:43 AM
gman47
Mar 4, 2006 06:36 PM
ludeless
Jan 18, 2006 01:01 AM
