Rear Door locks non-op
Old Jun 26, 2006 | 05:02 AM
Bboble's Avatar
Default Rear Door locks non-op
I have a 2001 S80 whose rear door locks do not function. I eiether have the master, or the service key, but not the remote one. When I use my key in the door, the driver opens, then the passengers, and the trunk, but not the rear doors. I have checked the fuse in the trunk... Is there anything else I can look for? Doubt it is something in the door as both do not work, maybe some module.
TIA
Old Jun 26, 2006 | 10:23 AM
Rex's Avatar
Rex
Default RE: Rear Door locks non-op
Hi, after unlocking the driver and passenger doors with the key...... have you also tried pressing the door lock button on the drivers side door? I know mine if often tempermental..... for instance if I am behind the wheel and my wife is trying to open a rear door it may take up to 5 clicks of the button for it to finally unlock for her.
Old Jun 26, 2006 | 04:19 PM
Bboble's Avatar
Ill have to give that a try when I am in the car... Hope that wouldn't be the problem, but Ford wiring[>:]
Old Jun 27, 2006 | 01:44 AM
Do you notice anything else not working?
Old Jun 27, 2006 | 06:23 AM
Bboble's Avatar
ORIGINAL: tech
I have the postion light bulb failure message, and I don't believe the lights under the mirrors function... But thought the position light was one of the four rear taillights. Also sometimes the once touch window function doesn't work on the drivers door. Thats all I can recall now...
Old Jun 27, 2006 | 08:30 PM
The reason I ask is because the Rear Door locks are controlled by the computer in the trunk.(Fuse panel) Called Rem(Rear Electronic module).
But if something is wrong with the Rem the Fuel guage and Rear windows won't work either.
You might need to have the codes pulled for the Rem and make sure there is none.
It might also just be both door locks bad.
rcvolvo
Jun 3, 2012 02:25 PM
Dbs
May 4, 2011 02:18 PM
CDSpin
Dec 16, 2010 12:19 PM
jhlillard
Mar 7, 2009 04:54 PM
fv70tech
Sep 17, 2008 05:26 PM
