Remove AC Compressor
Old Dec 23, 2010 | 10:08 AM
shopower's Avatar
Default Remove AC Compressor
I have a roaring noise comming from my AC compressor ('99 Volvo S80T6). I have taken it to a shop and they have vaccumed the system now I am going to take the compressor out of the car and replace the bearing to see if that will eliminate the noise.
Does anyone have instructions on how to remove the compressor?
'99 Volvo S80T6
Regards,
shopower
Old Dec 25, 2010 | 12:06 PM
ed7's Avatar
ed7
If you're looking to replace the clutch bearing, you don't have to remove the compressor. Rent a puller set from Auto Zone and work through the wheel well folding up the inner fender plastic as you would when doing the timing belt.
If you're replacing the compressor, remove the 4 bolts holding it in and remove through the wheel well. You can't replace bearings inside the compressor.
Ed
Old Jan 3, 2011 | 01:40 PM
shopower's Avatar
yes I am replacing the clutch bearing. There is no room to work on the compressor through the inner fender especially using a puller. In my opinion there is no access to the compressor through the inner fender on an S80 T6. I had to pull the compressor to replace the bearing. My buddy who is a machinist made up a puller for me to pull the clutch. I was then able to use a generic puller to pull the pulley then I was able to use a press to press out the bearing. (NSK 35BD219DUK) ordered the bearing off Ebay
check out the pics
Regards,
shopower
Old Jan 4, 2011 | 09:44 PM
ed7's Avatar
ed7
Pictures are always nice, bearing numbers too!
Not a cheap bearing, but less expensive than a clutch.
Thanks,
Ed
skamil
Sep 2, 2021 08:44 AM
sghokie
Jul 25, 2011 05:00 AM
camera cart
Jun 3, 2005 03:45 PM
etype38
May 4, 2005 07:08 PM
RonNaismith
Feb 28, 2005 07:24 PM
