SERPENTINE DRIVE BELT CRACKING
Old Oct 12, 2008 | 05:23 PM
  #21
E99S80T6's Avatar
Default RE: SERPENTINE DRIVE BELT CRACKING
So I found out what makes the noise the Belt Tensioner.Should I just change out the PULLEY or the whole assemby?
Heyafter I drain the coolant and it put coolant back in I started the car white smoke came out the exhaust along with some block liquid.
Old Oct 12, 2008 | 08:29 PM
  #22
The pulley should be fine.
How cold is it by you?
That might just be normal.
Did you drive it much after filling it?
If not it might purge some more when you drive it. Sometimes they will burp and the level will drop up to 3 to 4 times.
Old Oct 12, 2008 | 10:29 PM
  #23
E99S80T6's Avatar
I drove it for about 60 miles and it's at the same level. Here in Southern California durning the day it goes up to 100 and at night drops to 60.
Once the belt is off ... how do I take off the tensioner pulley?
Old Oct 13, 2008 | 07:52 AM
  #24
You will have to take the tensioner off then swap the pulley over.
Old Oct 13, 2008 | 01:04 PM
  #25
E99S80T6's Avatar
Okay. So is there a bolt in the center of the pulley? If not how do I take it off?
HEY! Tech can you tell me how to check the resistence on the speed sensor and where are they located?
Old Oct 13, 2008 | 01:27 PM
  #26
Yes there is a bolt in the center.
For the sensor the front ones might plug in at the sensor if not find the plug usually under the hood. Unplug it and hook the OHM meter up to the sensor side and spin the wheel and make sure the ohm meter moves. As long as it moves the sensor should be fine. But if it doesn't move at all then the sensor is most likely bad.
Mr diy
Nov 23, 2014 04:43 AM
Tim Sway
2001-2013 model year V70
Apr 12, 2013 10:43 PM
iscwebe
Feb 9, 2010 12:50 AM
Arsenal6
Mar 10, 2009 08:10 AM
hfs
Feb 25, 2009 02:37 PM
