Stop Lamp Brake Lights
Check Stop Lights keeps popping up on the dashboard. After a few minutes or several steps on the pedal the message goes away. The lights work. But it keeps failing everyday.
I replaced the stoplamp switch on the brake pedal. Still not working correctly.
I replaced the two bulbs in the rear, still not working correctly.
Eventually they work so there must be something else wrong.
I have a DiCE and ViDA it it tells me that nothing is wrong!?
I've checked the fuses also. All good.
Is there a relay that may be failing? If so, where is it?
Any suggestions are appreciated.
2001 S80 2.9
2001 S80 2.9
