Tech help! Coolant issue
OK tech you have helped me a few times.... I had a previous issue where the upper radiator neck was cracked so i kept leaking coolant at high pressure when the car was turned off. so i replaced the radiator completely and got a new upper radiator hose. So a month or two later (today) i started smelling coolant while driving it wasnt leaking that i could tell. Then at work i see a puddle below. its leaking somewhere by the drivers side front wheel... or at least thats where its rolling of the undercarriage plastic. but isnt that kind of far back ? what do you think the possibilities are or what to look for that holds coolant back there ?
ok so it was the hose going into the cab im assuming thats for heater core. it was dripping so i pushed up and tightened it. Hopefullyl thats all it was to replace the cuppler type thing doesnt look fun. Either way thanks for the help I at least found out what was leaking !
http://i187.photobucket.com/albums/x...volvodrip2.jpg
http://i187.photobucket.com/albums/x...1volvodrip.jpg
click link to see image
can i replace that black plastic coupler ? the volvo place around me said its part of the heater core. but it looks like it can be replaced. I only spoke with them over the phone tho.
have any part numbers or tips ?
[IMG]local://upfiles/16979/1F50DB08E3BB484794A476494F027C53.jpg[/IMG]
[IMG]local://upfiles/16979/79280A247DE34744BFA2078063C31425.jpg[/IMG]
so i might have found the part
http://catalog.autopartsgiant.com/Sh...es&mode=PA
dont know if its part 117 53087 001
[/align]or[/align]part 117 53088 001
[/align]the hose on right is the one leaking[/align][/align]
spankey
Oct 16, 2010 12:48 PM
