timing belt
Old Apr 14, 2007 | 01:05 AM
Ahmed's Avatar
Default timing belt
hello,
I have a 99 S80 with 112k miles and I know that the timeing belt replacement with the tensioners is past due. If the timing belt breaks on the highway on high speed does it cause more damage to the engine if it breaks at low speed. Also my Volvo dealership keeps telling me that there is no way that the timing belt can be inspected because it is inside the engine and that they would have to take the entire engine out to inspect it.
Old Apr 14, 2007 | 04:04 PM
billofdurham's Avatar
Default RE: timing belt
Doesn't really matter what speed you are doing, when it goes there will be significant damage. I lost a T/belt whilst the engine was idling. It needed two pistons and all new valves. Fortunately, it was a work vehicle so cost me nothing.
There is no need to remove the engine to inspect or replace the belt but the dealer was probably trying to tell you that there is a lot of parts to remove to inspect it. A visual inspection would not tell much any way.
Old Apr 14, 2007 | 06:44 PM
gordon368's Avatar
isnt the timing belt for these cars good till 120,000 miles?
Old Apr 16, 2007 | 01:09 PM
T6 4 me's Avatar
I was told 100000 miles, $200 for parts and 1 hr labour direct from Volvo. The S80 has an interference engine and it will cause engine damage if the belt jumps or breaks.
7zarc7
Mar 24, 2010 07:17 AM
04v70
Jul 17, 2009 11:01 AM
bcon415
Sep 19, 2008 07:17 PM
Soloracer
Aug 26, 2006 04:43 PM
Qamar
Aug 24, 2005 07:37 PM
