Tire size
Old Aug 19, 2007 | 12:53 AM
wooow's Avatar
Default Tire size
What is the biggest tire size that will fit into 2002 S80 with a 19x8 sized wheel?
Old Aug 19, 2007 | 11:22 AM
S70driver's Avatar
Default RE: Tire size
225/40-19
235/35-19
Might be other options but this is what I found for a 19x8 rim.
Old Aug 20, 2007 | 01:14 AM
wooow's Avatar
Thanks for the info. I was wondering if 245 45- 19 will fit without any modifications. I now have 235 35-19 and when wheels turn all the way, there's some scraping at the wheel wells already.
Old Aug 20, 2007 | 09:06 AM
S70driver's Avatar
"205 - Width in millimeters of tire from sidewall to sidewall."
And in your case you want 245.
205mm = 8.07086614173 inches
245mm = 9.64566929134 inches
So if I am correct 235mm = 9.25196850394 inches which your running currently. And again if I am correct that means your running a 19"-19.5" rim? Thusly going with a 245 tire it would be that much bigger thusly still have rubbing issues. I might be wrong. If I am someone correct me. I know my numbers are correct though. Did that on a calculator with a conversion program.
Old Aug 20, 2007 | 11:03 AM
wooow's Avatar
Yeah I would still have tire rubbing. Probably more with 245. Just have to not turn the wheel all the way. Figures seem correct.
Old Oct 21, 2007 | 12:17 PM
Finklespuss's Avatar
Hi wooow. I had 18" wheels and (UK, and possibly differently sized) 235x40 ULP tyres, and I too had scrubbing on full lock. Also, the ride was dead hard: tyre-roar very pronounced: turning circle unbelievable, and the mileage from these big fatties, was diabolically low - 13k was the norm. When I bothered to work out that I was never going to use more than about 70% of the car's potential, and wasn't likely to be hurtling around corners in the head-down, ***-up position, I binned the whole lot, and bought 16" & 225 x 55 tyres. Ride is now much more quiet and comfortable: turning circle "acceptable", and I should get double the mileage from a set of rubbers. Now much wiser (and one hell of a lot poorer) but experience tends to work out expensive. Happy motoring. Mike.
HummerGuy
Oct 10, 2008 08:02 AM
Meglog
Aug 17, 2006 02:48 PM
postdoc99
Feb 3, 2006 09:38 PM
AaronD81
Dec 7, 2005 09:34 PM
volvobacon
Dec 1, 2005 10:50 PM
