Tire size change?
Old Jul 11, 2009 | 08:08 PM
howardr's Avatar
Default Tire size change?
Can anyone tell me what I can expect if I change the tires on my T6 from 225/50/17 to 225/45/17?
Old Jul 11, 2009 | 09:50 PM
andrei3333's Avatar
speedo will read a little faster than you are actually going, the gap between the fender's will grow,,,, i guess its ok , im contemplating the same, those 50's are harder to find used, but new they are readily available,,,
Old Jul 13, 2009 | 09:05 AM
Eagle's Avatar
The best way to determine the correct size to run for speedometer accuracy is simply by the manufacturers RPM which in this case is Revolutions per Mile. From there you can determine how much it will be off or not if you match the Rpm hope this helps. -JS
Old Jul 16, 2009 | 03:46 PM
howardr's Avatar
Thanks for the help gents!
HummerGuy
Oct 10, 2008 08:02 AM
Meglog
Aug 17, 2006 02:48 PM
postdoc99
Feb 3, 2006 09:38 PM
AaronD81
Dec 7, 2005 09:34 PM
volvobacon
Dec 1, 2005 10:50 PM
