Trans Fluid
Old Jan 11, 2009 | 09:27 PM
benithegreat's Avatar
Default Trans Fluid
Is there another type of Trans Fluid that I can buy for a 2002 S80 2.9 non-turbo instead of buying it from the overpriced dealer?
Old Jan 11, 2009 | 09:32 PM
andrei3333's Avatar
Default RE: Trans Fluid
the fluid is synthetic, you just have to match the specs, check your manual for the proper spec...volvo does not make its own fluids so it should not be a problem to match it, i would still rather go to volvo just to be safe, you dotn want to take chances on your tranny, this is not engine oil you know
Old Jan 11, 2009 | 09:35 PM
yeah thanks ill check it out the reason I asked was because when I got hit in the left front tire all my transmission fluid leaked out.
Old Jan 11, 2009 | 10:11 PM
andrei3333's Avatar
yeah the axle probly was damages right ?
yeah i was inquiring about that cause i want to replace the fluid, the tranny pan doesnt even have a drain plug, you can get a kit that includes the gasket and the filter ( yes there is a filter, not just a simple magnet ) the tech at the tranny shop tells me you dont need to replace the gasket because its a metal bonded gasket with rubebr on both sides, so maybe you can get just the filter, i rather be safe and do things right - do it once, if the gasket leakes you need to replace more fluid for no reason you know ?!?!?!
look into it further with these trannies being GM low quality you wanna take care of them a little better you know
Old Jan 12, 2009 | 09:33 AM
I just contacted my dealer and asked them if they sell ATF fluid and they said that for a 2002 S80 2.9 non-turbo its STANDARD trans fluid and that they dont sell it in containers. I asked them which one I should buy from the store then and they said Dexron 6 or 5. I looked in my owners manual and it said Dexron 3 they said it doesnt matter if you mix any of the Dexron 3 or higher.
Old Jan 12, 2009 | 05:33 PM
andrei3333's Avatar
i would not mix, besides why is the dealer not sure which one you need 5 or 6, its inconclusive i would say try to call another dealer and see what they say
Old Jan 12, 2009 | 08:01 PM
Idk why but they said you can mix Dexron 3-6 so I didnt want to spend $7 a quart on Dexron 6 because I needed about 14 quarts and that would cost me $100 to fill up my trans so I finally found my manual and in it it said to use Dexron 3 so I bout that for $3.50 a quart.
Old Jan 12, 2009 | 08:19 PM
andrei3333's Avatar
there you go, dont listen to the dealer
nortons
Feb 22, 2015 11:14 PM
VolPat
Jun 15, 2012 08:06 PM
ded137t5r
Jun 10, 2012 07:40 PM
Eric's Hot Rod Shop
Jul 14, 2011 08:26 AM
VTBricked
Nov 21, 2009 07:50 AM
