Transmission Issue
Old Jan 23, 2015 | 08:30 PM
Sherry007's Avatar
Default Transmission Issue
Hi, I have Volvo s80 1999 2.9 Non Turbo.
Replaced Transmission on 145000 KM.
Recently done brake fluid change and unfortunately couldn't done rightly and brake switch kept on while drive.
So, I felt heavy on drive and ended up watching "Transmission, Urgent Service" Message.
Next day it starts slipping on 3 and 4 gear but If I kept RPM Less than 2000, It does not slip. Changed fluid and filter did not help. But during resting the fluid change counter, checked the solenoid and 3/4 ones were not getting on...but later on and off start on the diagnose computer.
Problem still persists, anyone can advise do I need to overhaul whole transmission or change the valve body or sensors?
Note: While fluid change there was not much gunk on the magnet or else where inside pan as I saw in my last transmission when it was failed on 145000.
Now its 190000 KM.
Will appreciate your opinions.
acpenn
Feb 25, 2014 06:50 PM
Earthfromorbit
Jun 15, 2011 03:14 PM
JRWilding
Nov 1, 2006 01:59 PM
Psaboic
Sep 18, 2006 08:35 PM
themeat
Oct 12, 2005 12:37 AM
