Volvo ECM ETM Throttle Body Coverage
Old May 25, 2006 | 08:54 PM
jerryman's Avatar
Default Volvo ECM ETM Throttle Body Coverage
Pulled this from the Volvo site and think now that all those in * are covered till 10yrs 200k.
Tech, is this right.
2000/2001 Emission Warranty Parts List -
Federal - U.S. and Canada
The following are some items covered by the Emission Warranty for two (2) years or 24,000 miles/40,000 km, whichever occurs first. Volvo has continued coverage on these items under new car warranty to four (4) years or 50,000 miles/80,000 kilometers, whichever occurs first. This only applies to engines/models, components, or systems fitted with those items. Components marked with one "*" are covered by the Long Term Warranty for eight (8) years or 80,000 miles/130,000 km, whichever occurs first.
Ignition System
Ignition Coil with Integrated Power Stage
Motronic Engine Control Module (ECM) *
Spark Plugs
Knock Sensor (KS)
Engine Speed (RPM) Sensor
Continuously Variable Valve Timing(CVVT)
Air Assist Control Valve
Ambient Temperature Sensor
Electronic Throttle Module**
Fuel Metering System
Fuel Pressure Regulator
Mass Air Flow (MAF) Sensor
Multiport Fuel Injection (SFI) *
Control Module
Fuel Injectors
Engine Coolant Temperature
(ECT) Sensor
Heated Oxygen Sensor(s)(HO2S)
** Not Applicable to S40/V40
Page 33
Fuel Metering System - continued
Manifold Absolute Pressure
(MAP) sensor
Camshaft Position (CMP) Sensor
Evaporative Emission System
Fuel Filler Cap
Vapor Storage Canister
Fuel Filler Pipe
Purge Control Valve
Positive Crankcase Ventilation
PCV Calibrated Orifice
Air Intake System
Intake Manifold
Turbocharger (TC) Assembly
TC Wastegate Actuator
Charge Air Cooler (CAC)
Catalyst System
Three-way Catalytic *
Converter (TWC)
Exhaust Manifold
Exhaust Pipe (Manifold to TWC)
* Covered by the Long Term Defect and Performance Warranty for eight (8) years or 80,000 miles/130,000 kilometers, whichever occurs first.
Old Oct 16, 2011 | 10:39 PM
volvoman248's Avatar
Default Ecm Outlet was able to repair my 2005 Volvo xc90
I sent this company my xc90 ecm and they repaired it. It no longer misfires as it did before. I thought my only option was the Volvo dealership but I was wrong. The name of the company is Ecm Outlet and the website is easy to find online. My xc90 is now driving as it did when I bought it in 2005. I hope this helps you in fixing your xc90.
samiam114
Oct 22, 2013 06:52 PM
ithcy
Oct 18, 2009 12:38 PM
romank01
Sep 12, 2009 09:39 AM
jerryman
Apr 16, 2008 09:12 PM
wolfspiritky
Apr 12, 2008 07:48 AM
