Wheel/Rim Repair Problem
Old Mar 24, 2010 | 10:29 PM
Jabber's Avatar
Default Wheel/Rim Repair Problem
I blew out a tire and damaged one of my 18" Zubra rims on my '08 S80 T6 hitting a pothole. The outside of the rim seemed fine, but the inside was clearly bent. I took it into my local Volvo dealer who has a third party wheel specialist that comes once a week and I paid $150 to repair the wheel. When I picked up the rim I was surprised to see that the damaged tire was still on the rim and the rim was still dirty. I expressed my displeasure but then had a new tire mounted and balanced at a tire shop other than the dealer because the dealer's price for the tire and mounting was simply outrageous. I also rotated the tires so that the new one is on the rear passenger side. There is still considerable tread, approximately 9/32 on the other three tires. When the installer mounted the tire he said that the repair was "a little off" and that they would use weight to compensate and that I would most likely not notice. Well I do - there's clearly a vibration coming from the rear and you can feel and see the passenger seat vibrating when cruising on the highway.
I did some research and it appears that most wheel repair shops remove the tire and use heat to repair the damage to ensure that it is within a minimal tolerance of round. Armed with that knowledge I went back into the dealer today and was told that because the Zubras are alluminum rims that heat should NOT be used because it makes the metal unstable and that a cold fix is better and that it is NOT necessary to take the tire off the rim to make the repair. I called a couple rim repair places (this is all they do) and was told that that is nonsense.
Whom am I to believe?
Old Mar 28, 2010 | 08:15 AM
75ohm's Avatar
I have and will only use Transwheel to repair/restore rims... and that is why.
Old May 21, 2011 | 11:09 PM
The Bear's Avatar
Having my rear rght wheel repaires MOnday by a firm that my local tire dealer recommends. I trust the tire dealer _ have been using them for apprx. 25 years, th one time they made a mistake, this was rectified by the owner/manager, and they paid for it! S Iam looking forward to an eexcellent jobbeing done. Tire is a michelin pilot.
Old Jul 17, 2023 | 05:45 AM
VinR1's Avatar
Originally Posted by Jabber
I blew out a tire and damaged one of my 18" Zubra rims on my '08 S80 T6 hitting a pothole. The outside of the rim seemed fine, but the inside was clearly bent. I took it into my local Volvo dealer who has a third-party wheel specialist that comes once a week and I paid $150 to repair the wheel. When I picked up the rim I was surprised to see that the damaged tire was still on the rim and the rim was still dirty. I expressed my displeasure but then had a new tire mounted and balanced at a tire shop other than the dealer because the dealer's price for the tire and mounting was simply outrageous. I also rotated the tires so that the new one is on the rear passenger side. There is still considerable tread, approximately 9/32 on the other three tires' rim repair near me. When the installer mounted the tire he said that the repair was "a little off" and that they would use weight to compensate and that I would most likely not notice. Well, I do - there's clearly a vibration coming from the rear and you can feel and see the passenger seat vibrating when cruising on the highway.
Inner wheel rim leaks air slowly. Dealer said to have alloys refurbished by a specialist company. This costs a few hundred pounds. Is this the only solution or should I take it to a tyre shop and could they clean the inner rim of slight corrosion and reseal it? Anyone had the same problem? Thanks.
ZZtech
May 8, 2022 02:20 PM
SB245
Dec 14, 2015 11:26 PM
hood1227
May 5, 2013 06:48 PM
malaka
Apr 6, 2011 08:37 AM
mikkowus
Mar 19, 2010 10:06 AM
