Why can't I get an answer on my thread???????
Old Apr 15, 2010 | 12:45 PM
wlfire55's Avatar
Default Why can't I get an answer on my thread???????
I have a 2000 S80 T6 that runs good, but after it is warm and you turn the engine off, when you restart it while still warm I usually get a message that says "ENGINE SYSTEM SERVICE REQUIRED" and the little triangle in the middle of the gauges is orange. When I check for codes there are none, but when I erase for codes it will clear the message. WHat does this message mean??? Also once in a while a message that the DTSC needs serviced, what does that mean?
Thanks
Old Apr 15, 2010 | 03:29 PM
jlewisinsyr's Avatar
A lot of scanners will not read all of the codes stored in a Volvo, you'll probably need to go to a Volvo shop to have it scanned.
Old Apr 15, 2010 | 03:34 PM
alkali2010's Avatar
My suggestion, stick to one question park per question
But I honestly don't know, and I'd rather give no advice than bad advice. Perhaps check your area for a volvo mechanic; usually they don't charge for simple diagnostics in my experience.
Old Apr 16, 2010 | 06:29 AM
vegasjetskier's Avatar
DSTC is Dynamic Stability and Traction Control. You might have a problem with one of the ABS sensors or the ABS module may be going bad. Like someone else said, try to have the codes read by a shop with a Volvo-specific scanner.
thegazelle
Jul 8, 2014 09:44 PM
akorcovelos
Jul 14, 2008 06:41 PM
Scott6
Nov 20, 2007 10:45 AM
Coastal
Oct 4, 2007 05:22 PM
