About to do a front-end brake job. What will I need?
Old Dec 16, 2010 | 02:26 PM
I8ASaleen's Avatar
Default About to do a front-end brake job. What will I need?
Alright guys I'm no newcomer to brake jobs in general, but I have not ever done one on a Volvo. I have a 97 S90, just wondering if you guys have any suggestions on pads, rotors, any sensors I would need, special techniques, etc...
Old Dec 18, 2010 | 10:35 PM
Nope. Pretty easy and straight forward. Rotors are easy to remove, no special tools or anything.
Old Dec 21, 2010 | 05:10 PM
I8ASaleen's Avatar
Good deal, nothing special about pushing in the calipers either?
Old Dec 22, 2010 | 10:13 AM
No. I will post photo instructions later today. I used a c-clamp. The caliper has a solid tab on it to support the clamp on.
Old Dec 24, 2010 | 02:22 AM
I8ASaleen's Avatar
Sounds just like my T/A. I had to use an 8" c-clamp for it.
Old Dec 24, 2010 | 10:24 PM
Not sure if these instructions will help but here is how they are done on the S70.
http://www.atthetipwebs.com/technolo..._front_s70.htm
Old Dec 30, 2010 | 12:07 AM
I8ASaleen's Avatar
sweet. But now I have ABS probs to fix. So I figure I will get the parts for that and fix it all at once.
Old Sep 16, 2013 | 05:20 PM
kg4ibj's Avatar
The sliders will turn, but they are not loosening so the caliper can be removed. I looked at the instructions and my S90 doesn't have the clips or the 8mm screws he mentions. Any thoughts? I've changed pads previously on other vehicles not on my New to Me S90.
Old Oct 3, 2013 | 02:43 AM
Bob_fromLA's Avatar
The slider fittings have flats that you can grab with a wrench (or simply holding them by hand has worked for me). Good luck, the S90 brakes are pretty easy to work on. However, the mounts that the slider pins fit into do wear over time. The Volvo sourced "remanufactured" caliper mounts actually had holes that were worse than the ones on our car, they were simply used mounts that were cleaned and spray painted gold! One of the slider holes wears more than the other, so I got some benefit by simply swapping the mounts side to side. I note that some of the replacement "loaded calipers" come with mounts as well, but I have not tried them.
The front hubs on the S90 have radial runout marks that you could line up with marks on the old OEM Volvo rotors, when doing that mine were always in runout spec and I never had to get the rotors ground. The current Volvo sourced rotors are Chinese instead of Italy / Brembo, so all bets are off on those. I think Rock Auto still offers Brembo rotors, but they may not be OEM and may not have the radial runout marks.
PaddyG
1998-2000 model year V70
Feb 17, 2014 05:23 PM
sotlm2noles
Dec 13, 2010 07:55 PM
atownpdx
Dec 1, 2007 09:42 PM
master_pre
Sep 30, 2006 04:35 PM
gtiguy
May 7, 2005 11:02 AM
