air conditioning stops blowing
Old Aug 24, 2020 | 02:36 PM
steve2018's Avatar
Default air conditioning stops blowing
2018 S90 T6 Momentum
trip to Boston 90 miles air conditioning works fine, visit hospital for 1.5 hours back to Springfield half way home air will get weak and you can hear the fan working but, it like a door is not opening???
let the car sit awhile and it goes back to working. happened only 3 times on separate trips. never just around town? It was a certified used purchase February 2020 so maybe it has to go in for a check.
any info would be appreciated,
thanks, steve2018
Old Aug 24, 2020 | 03:01 PM
Your ac is probably freezing up, the evaporator is too cold, freezing the condensation on it, and the ice builds up until it blocks air flow. After the car sits and the ice melts ac works normally again. If it happens again before you get it fixed, when it stops blowing turn the compressor off and turn the heat on - that will melt the ice quickly.
Something is making your ac too cold - I have read there is a software fix from Volvo.
Old Feb 2, 2021 | 03:49 PM
steve2018's Avatar
hoonk,
Just read your response to my ac problem again.. i hope I thanked you back in July for your response. I made it through the rest of the Summer with the AC, its Winter now but, I'm do for my 30,000 mile service and i will ask about all that you suggested.
Thanks again, Steve
PS i will text back how i made out
Old Feb 2, 2021 | 04:25 PM
also have the shop test for the correct system pressure to make sure its not over or under charged.
Old Feb 2, 2021 | 06:34 PM
steve2018's Avatar
Hello mt6127
Thank you for your tip, i will ask them about what you said.. I will be using Mitchell Volvo cars of Simsbury CT in your state as i do not trust any Volvo dealers in my state MA
Thanks again, Steve
Old Apr 8, 2021 | 06:52 PM
steve2018's Avatar
hook,
Finally got to my 30,000 mile check up. The mechanic agreed with you that a software fix might work for my AC problem of freezing up. he refreshed/ updated the computer and said to try it. if it's not fix they need it over night and will give me a loner to see what else they can try.
Also with the refresh of the computer the car is not searching for a gear when you turn a corner it's nice and smooth now. before when you slowed and turned a corner and started with the gas again it would like hick up looking for the right gear to continue. Now it's a nice smooth transition to the right gear. I always thought that was weird shift on corner glad it's seems to be corrected.. Also seems to accelerate smoother.
Thanks again for your tip and your time to answer my question.. i hope it helps someone else maybe.
Steve
Old Apr 9, 2021 | 03:38 PM
steve2018's Avatar
hook,
Steve
first477
Apr 26, 2022 02:46 PM
turbobill
Oct 11, 2013 12:58 AM
jpuleo
Jul 24, 2011 01:01 PM
ozarkboater
Jul 5, 2006 09:17 AM
mtidwell
May 2, 2006 09:15 PM
