Driveline slip when cold (Automatic Trans, S90)
Old Jan 3, 2014 | 01:56 PM
black360's Avatar
Default Driveline slip when cold (Automatic Trans, S90)
Anyone experience slippage with very cold tranny?
Feels like the torque converter is slipping; exhibits the same problem in forward or reverse gears; no problem after a little bit of warm up.
Maybe a stickly valve in the valve body? Any ideas?
Thanks.
Old Feb 26, 2014 | 07:21 AM
oragex's Avatar
I would have the fluid level checked.
Old Feb 27, 2014 | 03:20 AM
black360's Avatar
Fluid indicates that level is within specification.
The problem is sporadic; did not suspect fluid level.
Old Oct 2, 2014 | 06:22 PM
SLOjohn's Avatar
Flush the transmission fluid and change the filter. Check to see if water from the radiator is entering into the transmission cooler lines, the seals can fail and allow coolant into the transmission. The transmission is made by Aiken and is the same one used by Lexus, it is a very solid unit and almost indestructible.
twiin64
Oct 30, 2017 05:47 PM
lovmyvolvo
Forum Issues
Feb 14, 2015 09:49 AM
bhhardgr
Nov 13, 2012 06:39 PM
ded137t5r
Jun 10, 2012 07:40 PM
GreenBrick
Aug 19, 2008 08:33 AM
