gear lever parts
Old Jul 12, 2015 | 09:01 PM
Don98S90's Avatar
Default gear lever parts
Can anyone tell me what part # 39 "Cable" does? It comes into the Gear Lever Carrier from the front directly below the ash tray. It attaches to a plastic barrel shaped part in front of the gear shifter.
This is what I think is happening. The gear shifter will not moving out of park when the notch connection between the cable and the barrel shaped part is not fully pushed back against the gear shift when you squees the head of the gear shift. The override button and its wire is suppose to force the plastic barrel shaped part into the correct position. When all the other parts do not work correctly. I am wondering what the cables job is in the proper operation of the Gear Lever system. If anyone has the correct sequence of operation for all the parts in the Gear Lever Carrier I would appreciate a copy or direction to the information.
Thanks for any help. Don and my 98S90 will thank you also. She wants to go for a drive soon.
Old Jul 13, 2015 | 06:26 PM
VDonkey's Avatar
What are you looking at, where I can see what you mean by "#39 Cable?"
Old Jul 14, 2015 | 02:45 PM
Don98S90's Avatar
Default my item number came from Volvo PV43069912
Hello,
I information came from Volvo Genuine Parts PV43069912. Item 39 is a cable that attaches to one of the plastic parts in the gear shift assemble, travels under the ash tray and into the dash area. I do not know what its function is or where it attaches under the dash. I have not determine how find out if it is functioning correctly.
Thanks for any help you can give.
Don
m.olennick
May 3, 2012 03:41 PM
tom0317
Aug 4, 2009 10:16 AM
mrv70
Jan 6, 2006 12:07 AM
Qamar
Oct 14, 2005 06:22 PM
Qamar
Aug 27, 2005 07:25 AM
