V40 1.9 TD 2004 Reverse Light Intermittent
Old Nov 11, 2007 | 11:14 AM
chamonix's Avatar
Default V40 1.9 TD 2004 Reverse Light Intermittent
Reverse light on my V40 is intermittent. Some times it comes on, most times not. Its a manual, any ideas to solve this problem?
Many thanks
Old Nov 11, 2007 | 11:11 PM
tripleb's Avatar
Default RE: V40 1.9 TD 2004 Reverse Light Intermittent
I'm not familiar with the manual trans, but it should have a reverse light switch, I would check that.
Old Nov 12, 2007 | 10:53 AM
billofdurham's Avatar
To get to the reverse lamp switch disconnect and remove the battery, making sure you have a radio code if one is needed.
Remove the air cleaner housing, exposing the gearbox mounting.
Apply a jack lightly under the gearbox.
Slacken the nut for the gearbox mounting and remove three bolts from the mounting. Fold it up and tighten the nut.
You can now see the reverse lamp switch. Check the connectors and check for 12v. If 12v is present suspect a faulty switch.
Clean around the switch and remove it.
If the switch is replaced tighten it to 25nm.
The three bolts in the engine mounting are tightened to 50nm.
Replace the locknut on the gearbox mounting and tighten it to 98nm.
Replace the air cleaner housing and battery.
Garon
Apr 22, 2009 02:57 PM
rick_lindsey
Aug 25, 2008 09:37 PM
Stewie
Feb 18, 2008 04:46 AM
rousha
Jul 19, 2005 05:18 PM
