Alternatives to volvo vacuum tester?
Old May 29, 2008 | 05:37 PM
sporky's Avatar
Default Alternatives to volvo vacuum tester?
I need to check for leakage in my intake system. The "Volvo" way of doing it, according to VADIS, is to use positive pressure in the system and soap solution to look for air leaks. I know that carb cleaner and propane can be used in a similar manner, but I like the idea of not having the car running while checking pressure...less background noise to listen for hissing sounds. Any suggestions for rigging a homemade solution of putting positive pressure in the system?
[IMG]local://upfiles/16414/1A854D6FEAB540D4B3EF6FF7EAC00DF9.jpg[/IMG]
Old May 29, 2008 | 06:35 PM
Default RE: Alternatives to volvo vacuum tester?
https://volvoforums.com/m_97871/tm.htm
I made this and use it to find leaks.
Old May 29, 2008 | 06:46 PM
sporky's Avatar
Nice rig! I don't have one of those caps you used from a new intake hose...have you any ideas for an alternative that I could find around the house or perhaps at the hardware store?
Also, since I replaced the seals on my injectors, is there a way to use your tool to test for leaks along the rail?
Old May 29, 2008 | 07:37 PM
The tool will pressurize the intake system and crankcase system.
Maybe a pvc cap will work. I haven't tried but there might be one close to the sized you need.
Old May 29, 2008 | 08:07 PM
sporky's Avatar
ah, PVC cap in the plumbing section...I'll have to take the hose into Lowe's and check that out...thanks for the idea!
Old May 29, 2008 | 08:28 PM
No problem let me know how you make out.
Old Jun 3, 2008 | 08:24 PM
sporky's Avatar
tech...I've got quite a bit of air flowing out of the oil fill hole...are you still able to pressurize the engine to 3 or 4 psi with the leaking air? I don't want to push it and blow a seal out.
edit...or it could be that I just forgot to clamp off the PCV hose and air is venting straight from the flame trap through the engine block and out the oil cap...doh!
Old Jun 4, 2008 | 06:44 PM
You don't need to pinch off any lines.
I stick a rag between the oil cap and the cam cover. Then test yes you can still find a leak that way.
Old Jun 4, 2008 | 07:33 PM
sporky's Avatar
Your engine will actually hold air enough to build 3-4 psi with just the rag filling the hole?
Too much air is coming out of the oil hole on my car...can't build any pressure
Old Jun 7, 2008 | 07:52 AM
It should still hold some pressure. It is going through everything still try spraying everything with soapy water.
acvolvo
May 15, 2011 01:51 PM
Saleen9090
Jul 17, 2009 07:32 PM
petes99xc
Oct 26, 2008 07:59 AM
dannydoo
Oct 15, 2006 05:58 PM
revdevil
Feb 16, 2006 10:34 PM
