brake lights stay on
Old Oct 20, 2007 | 12:37 PM
ridgelane's Avatar
Default brake lights stay on
The brake lights on my 99v70r will not go off unless I pull back on brake pedal. I recently made a panic stop. Is there a part that broke that needs to be replaced?
Old Oct 20, 2007 | 04:33 PM
v70 2.4t's Avatar
Default RE: brake lights stay on
I would say your brake light switch is bad,
You may have damaged it with the panic stop.
not a big fix about 15 min or so job to replace.
good luck
v70 2.4t
Old Oct 20, 2007 | 05:04 PM
Was anyone under the dash lately?
The switches are adjustable. It might just need to be adjusted.
Remove the lower dash panel and look for the switch. There is 2 under there. One with a vaccum hose (cruise switch) and one with just wires.
Push the brake pedal down and push the switch towards the pedal and release the pedal. That is do that to the switch without the vaccum line.
Old Oct 21, 2007 | 04:16 PM
ridgelane's Avatar
Thanks Tech,
That was the problem. I just had to adjust the switch.
Hanna
Dec 22, 2010 02:14 PM
satchmodog
Nov 9, 2006 08:40 PM
spinningcain
Aug 20, 2006 02:52 AM
mr.zorak
Aug 14, 2006 01:05 AM
salkenn
Dec 4, 2005 11:00 AM
