Can a worn turbo cause antifreeze burning?
I have antifreeze burning in my exhaust. GREAT...
I was think head gasket (car has 220k on it)
BUT- when I did c compression test here were the results.
1 2 3 4 5
160# 162# 165# 168# 170#
All looks good right?
I have NO water in oil or oil in water. It started steam on the exhaust after sitting at idle for about 15 minutes.
Thoughts???
Turbo has about 100k on the last reseal. Can the water seal leak into the combustion chamber or what??
1 2 3 4 5
Thoughts???
Usually a turbo will not leak coolant into the exhaust. You might still have a bad head gasket. I would find someone that has the block test chemical kit and see if the head gasket is bad.
Take the spark plugs out and observe whether or not you can see evidence of coolant on them. If so, it is time for major surgery on the engine. Typically, the head will crack adjacent to the exhaust valve seat(s) if it does crack. The course of action is to have a machine shop do a pressure test on the head to see if it is cracked. If it is not cracked, you'll be able to have the head rebuilt and put it back on the car and go "Zoom-Zoom" again!
