Charge air cooler hose removal
Old Oct 3, 2009 | 10:52 AM
eyukins's Avatar
Default Charge air cooler hose removal
2004 V70R MANUAL TRANSMISSION
I'm replacing my A/C condenser and am having trouble removing the Charge Air Cooler hose, it seems to be very rigid and will not simply separate from the cooler.
Do I need to remove the other end of the hose (above the compressor), or do I just need to really pull on it?
Should I try heating it with a propane torch or hair dryer?
Thanks in advance for the help.
Attached Thumbnails Charge air cooler hose removal-v70-r-cac-hose.jpg   Charge air cooler hose removal-v70-r-cac-hose-2.jpg
Old Oct 3, 2009 | 11:06 AM
It is a plastic on plastic tube. You need to pull a little harder.
I usually push the pipe down almost like twisting it down to get it off.
Old Oct 3, 2009 | 12:14 PM
eyukins's Avatar
Thanks tech.
Old Oct 3, 2009 | 09:13 PM
Your welcome.
jriggs87
Sep 7, 2012 07:30 AM
svenska
Sep 22, 2010 10:50 AM
Karnage
Nov 20, 2009 05:19 PM
spunkymonky
Oct 15, 2008 03:00 PM
curtisckey
Jan 22, 2008 06:24 PM
