headlamp upgrade
Old Feb 18, 2012 | 06:07 PM
motosickle's Avatar
Default headlamp upgrade
i would like to swap out my 55w H7 low beams for 100w H7's..can the 50amp fuse handle the extra load?
thanks
Robin
Old Feb 18, 2012 | 07:28 PM
JRL's Avatar
JRL
I don't know, but the wiring harness can't, neither can the cars coming at you be able to see, neither will the police when they haul you off to the slammer, neither will anyone who may shoot you, etc etc
Are you THAT dumb?
Old Feb 20, 2012 | 01:30 PM
motosickle's Avatar
Are you THAT dumb?
gee,gues i am that dumb. i've been using 80/100 bulbs in my motorcycles for years. never been arrested ,never been shot at,and have the ability to see things at night from a distance.
i will say for a senior member your comments sure are a suprise
Old Feb 20, 2012 | 02:54 PM
stonepa's Avatar
Are you THAT dumb?
Really? You are right about the Volvo US wiring harness not being up to snuff. Not sure why Volvo included such a weak harness. My Mercedes 600 SEL that I bought new in 1992 came with these headlights (Hellas) standard. I added them to my 1988 Mercedes 300TE and drove it for 225k miles with no electrical failures.
It is not dumb and no, a cop will not cite you. IMHO all cars need brighter headlights than come standard. Any time you can outdrive your headlights at highway speeds your car is not safe.
Compliance with the law (and being nice to oncoming drivers) has little to do with the brightness of the bulbs and all to do with the headlamps being properly aimed.
Old Mar 2, 2012 | 12:22 PM
Scuba Jim's Avatar
Yea a little harsh on the dumb comment! I would not recommend upgrading to a higher wattage bulb. The reflective internals of the light could melt or warp from the extra heat. The load on the wiring harness could be dangerous as well.
Old Mar 17, 2012 | 03:45 PM
motosickle's Avatar
has anyone ever repainted int inside of the reflector with a chrome paint?
Old Mar 18, 2012 | 08:25 AM
Scuba Jim's Avatar
Chrome paint will not be as reflective as the OEM plating.
Old Jul 25, 2012 | 08:06 PM
95doyle's Avatar
You could always go with e-code lenses. E-codes have a slightly different pattern in the glass than DOT lenses. They are designed to aim all of the light at the ground while emitting a very pretty sharp cut off line. Because of this, they throw off roughly 20-30% brighter beams of light. If you just swap the lenses with e-codes and leave the stock 55w bulb, that alone will be a drastic improvement. If you also threw in an HID kit, that would be a night and day difference. Just make sure you use the same wattage. Remember watts are a unit of power (work/time), not light. First law of thermodynamics, "no work can exist without the release of heat." So more work = more heat, leading to premature deterioration of wiring harnesses. Hope this helps.
sixtyfourford
May 25, 2012 12:35 AM
S70driver
May 15, 2006 05:02 PM
Volvodaddy
Mar 25, 2006 11:39 PM
greatyazoo
Jan 6, 2006 12:13 AM
Volvodaddy
Dec 29, 2005 09:13 PM
