a lite question :)
Old Nov 7, 2008 | 10:59 AM
rules's Avatar
Default a lite question :)
Is there a way to get the fog lights to come on with low beams? Wiring or software mod?
Peace.
Old Nov 7, 2008 | 11:18 AM
Default RE: a lite question :)
Are you adding them to your car and your car didn't have them stock?
Old Nov 7, 2008 | 11:21 AM
rules's Avatar
Knew I forgot something ... from the factory
Old Nov 7, 2008 | 11:27 AM
If they came with the car they should only work with the lowbeams. When you turn the highbeams on they will go off.
Old Nov 7, 2008 | 11:31 AM
rules's Avatar
Hey, I never knew they went off with high beams. What I meant in the first post is, is it possible to have the fog lights come on automatically when switching on the lights? instead of having to press the button.
Old Nov 7, 2008 | 11:33 AM
Oh ok im not sure about that.
Old Nov 8, 2008 | 06:08 AM
rules's Avatar
Sorted Now my life is about 0.00000001% easier!
[IMG]local://upfiles/17180/90295FD92C424C73B8C23684E2E82D8F.jpg[/IMG]
Old Nov 8, 2008 | 06:13 AM
So did you just have to tap into a wire and jump it?
Old Nov 8, 2008 | 06:26 AM
rules's Avatar
The timer board's relay output is soldered (with a piece of wire off course) to the back of the pc board in the light switch module, on the fog light push button. So the 2 switches are in parallel. That way you aren't bypassing anything, you are just pushing the button electronically (instead of physically pushing it with your finger).
Old Nov 8, 2008 | 06:31 AM
Oh ok I was just trying to get as much info on what you did this way if someone else wants to do it they can.
Old Nov 8, 2008 | 07:48 AM
rules's Avatar
No Porb.
The reason I did it this way is because, as you know, damn near everything is software controlled (light switch gives input to controller and controller then decides what to do) and I didn't want to end up with a situation where the controller would start throwing errors or worse, burn something up (don't know how that could happen, but I don't want to be the first to figure out how ).
Old Nov 8, 2008 | 08:21 AM
LOL I hear you.
michelinep
Jul 17, 2020 05:29 AM
c note
Oct 25, 2011 10:29 AM
lady_macin
Mar 13, 2008 08:16 PM
bobh1959
Jun 6, 2007 03:21 PM
mktmkt
Mar 7, 2006 10:08 PM
