rear view mirror failing?
Old Aug 3, 2007 | 03:10 PM
earl's Avatar
Default rear view mirror failing?
I have a 2001 V70 T5 and it appears that the internal rear view mirror with the auto-dimming feature is failing. It looks like there is a fluid in this mirror and a clear area is appearing at the top and it moves from side to side as the car moves. Does anyone know if this means that I will have to have the unit replaced? If so, is it expensive? Easy for me to do myself? Thanks in advance. Earl.
Old Aug 3, 2007 | 05:29 PM
bobschwind's Avatar
Default RE: rear view mirror failing?
Yes, mirror is expensive (like every other part on these cars). I let mine go and eventually it cleared up. I had a dark spot in the middle of the mirror and when you pushed on it, it move like it was fluid. I think eventually it all fell to the bottom.
Old Aug 4, 2007 | 09:43 PM
You cannot replace it your self as it is a module and needs a software download to the car to make it work.
rvinson
Apr 3, 2021 12:23 PM
TimmyC
Apr 30, 2009 12:08 PM
Psaboic
Jun 4, 2007 07:30 PM
jrevenson
Apr 23, 2006 10:12 PM
blase
Jul 29, 2005 01:03 AM
