Seat Switch
Old May 11, 2006 | 12:31 AM
rmmagow's Avatar
Default Seat Switch
98 V70R.
The driver's side power seat switch that is used to move the seat back and forth seems to be acting up. It will move the seat back, but not forward. Pressing one of the memory buttons, the seat does move forward, so I think the mechanics are OK. Since the car is equipped with SIPS I am a little afraid to go poking around. Are the switches that move the seat easily and safely replaced? Are there instructions someplace about how to access them without blowing up the SIPS system?
Thanks Much.
Old May 11, 2006 | 02:20 AM
mo t5's Avatar
Default RE: Seat Switch
Dumb question, even though alot of people say that there is no dumb questions, heres one, whats SIPS? Mine has the exact same symptoms with the drivers seat.
Old May 11, 2006 | 08:44 PM
SIPS= Side Impact Protection System.
The panel can come off just be careful.
They aren't really easily set off. Once you lift the panel off you will see a silver round looking thing.It has a flat peice of metal looped infront of it kind of. On the back of the panel is a Red clip looking thing. Slide it inbetween the 2 metal peices. Then it won't setoff unless you take the seat out and drop it.
When the 2 metal peices hit each other pretty hard that is what sets it off.
Old May 15, 2006 | 08:56 PM
jmc00v70's Avatar
Dang! My 2000 V70 does the same thing. I can move it forward to a comfortable postion with one of the memory buttons luckily. But it will not move forward as it is designed to.
Old May 15, 2006 | 09:01 PM
Seat switch bad.
bennyd20
Sep 23, 2011 07:34 PM
snulma1
Oct 9, 2008 11:20 AM
guptash
Jan 24, 2007 10:31 PM
rmmagow
May 31, 2006 09:29 PM
