Transmission mode switch not working
RE: Transmission mode switch not working
I drive like a "Pa" most of the time and before I took the car in at a steady 30 mph you could switch it from Economy to Sport and the rpm's and tranny would switch. Move it back and the rpm's would drop. I do this now and nothing happens? Again the winter mode works fine? What else can I check?
Do you mean by using a special tranny code reader? I've put a ODBII scanner on it and there are no codes. THis is one my friend has. Maybe it needs to be a "real" scanner to see this? Let me know and I'll go have them read if this is what you mean but as far as I know I had this at another place and they were unable to fix it either. Maybe I need Volvo to fix it :-(
To qualify this better it's in Sport mode now. Winter mode works as it should by starting out in second or whatever it does but Economy isn't working. I drive this car very gently and don't abuse it at all but it would be nice to not have to speed up to shift up to slow down!
