Wheel play
Old Apr 22, 2011 | 07:04 PM
a4ty4d's Avatar
Default Wheel play
When I jack the front end of my 1998 V70 I get significant wheel play when I move the wheels with my hands at 3 and 9 o'clock. I don't get any wheel play when I move the wheel with my hands at 12 and 6 o'clock. Does this indicate that I need to replace my tie rod ends and not the control arms?
John 07 v50, 98 v70, 91 245
Old Apr 23, 2011 | 07:08 PM
ed7's Avatar
ed7
This is showing rod end play. Control arm play presents in wheel shifting forward and aft.
Play when grasping the wheel at 12 and 6 o'clock will show wheel bearing slack.
Ed
Old Apr 23, 2011 | 07:45 PM
a4ty4d's Avatar
Default forward and aft?
By forward and aft do you mean if I move it back and forth clockwise and counter-clockwise? Or laterally side to side forward and backwards?
Thanks.
Old Apr 24, 2011 | 04:25 PM
ed7's Avatar
ed7
Lateral shift. You'll look for deterioration of the rubber bushings in the control arms.
The bushings are, themselves, replaceable.
Ed
Old Apr 24, 2011 | 06:16 PM
natev70love's Avatar
yes, you'll probably pay like 50$ or so for the bushings, so getting two new control arm assemblies would be the best option(around 100$).
Old Apr 24, 2011 | 06:27 PM
jozeyg18's Avatar
OK i had the same issue & turned out to be my inner tie rod end of my Front right tire.
Now the problem has been fixed, but the suspension pops from time to time when your turning.
You can actually hear a loud pop.
Sorry for thread jackin.
but rather keep the same topic on here rather than to start another pointless thread
JOZEY
Old Apr 25, 2011 | 08:25 PM
a4ty4d's Avatar
I believe the popping indicates a worn cv joint.
Old Apr 27, 2011 | 01:32 AM
jozeyg18's Avatar
I will inspect them, but last I inspected them I did not notice any worn booth or anything.
I did notice a bad grease trail though, grease from the cv booth. But like I said it didnt appear torn or anything.
Unless its a small tear that i havent noticed.
I will do some further inspection, and post my finds.
JOZEY
alpac
Nov 25, 2024 12:31 PM
Martinsea
Apr 12, 2014 09:02 PM
tedv
Aug 16, 2009 01:02 AM
Ebolavoodoo
Sep 29, 2006 01:04 PM
cbatterman
Apr 8, 2006 02:42 PM
