Leak issue - water from roof?
Greetings!
I have a 2021 XC40 and love it - have had it for 4 months so far - and discovered the passenger side foot wells (both front and back) soaked after some extended periods of rain. (I’ll state the obvious - all windows and sunroof were closed)
The underside of the carpeting (dense foam backing) is soaked and there is water pooled beneath the carpeting. It’s back at the dealer now to investigate.
Any other owners experience any such issues?
The following 2 users liked this post by skr9:
Emsedee (05-07-2024),
prasanth240 (09-01-2021)
Roof leak
Greetings!
Good luck,
Jim
Carmen2021 (03-13-2024)
I took it back to the dealer; it was a drain from the sunroof not properly installed at the factory - so they had to remove seats and floor lining, dry everything out and make sure all the electronics were not damaged. No cost to me - but they had the car for a week and half due to all the labor involved. Unfortunately they were not even able to provide me a loaner as their loaner fleet has been sold off by the sales department as they have been affected by the computer chip shortage. I would get yours back to the dealer ASAP to have them investigate. Good luck!
Sounds like your sunroof drain is clogged. It is very common on Volvos with sunroofs. In the corner front there are two drain lines (one on each side) that drain water from the sunroof down the front pillars near the front window to the ground. When the roof is open sometimes small leaves or even pine needles get in there and don’t allow the water to drain. Since it’s only 4 months old bring it to Volvo and have them cleaned out as it is still under warranty. I had the same problem with my 2014 XC60. I haven’t had that problem with my 2021 XC40 (yet) but I’m always looking. Hopefully this helps.
Good luck,
Jim
Good luck,
Jim
Permanent cure for roof leaks
Volvo roof drain permanent fix.
Order the item below.
Remove pillar cover - remove stupid rubber drain tip (water may be trapped in drain tube - clean out tube in some way).
Install the silicone item - it's a perfect fit on drain tube and drain hole where rubber tip was. Replace pillar cover - done.
Never again - and a fraction of the cost of the original piece.
UPDATED INFO:
https://www.aliexpress.com/item/1005001990178665.html?spm=a2g0o.productlist.0.0.35 6c4e9caGCpPN&algo_pvid=95418235-f833-4e5f-b717-dfcde180ba65&algo_exp_id=95418235-f833-4e5f-b717-dfcde180ba65-1&pdp_ext_f=%7B"sku_id"%3A"12000021863708952"%7D&p dp_pi=-1%3B5.42%3B-1%3B-1%40salePrice%3BUSD%3Bsearch-mainSearch
Or try a search on this text or part of it:
3pcs Oil truck essential exhaust pipe muffler silicone Exhaust Extension Tube For RC HSP model 1:10 Nitro Car 02026 102009
There are plenty of other sources - prices vary quite a bit.
UPDATED INFO:
Water in the front Footwell - but No sun roof
Greetings!
Hi
I’ve had a wet passenger mat twice this week which is the first time since earlier this year - I was hoping this issue had resolved itself .. and I have no sunroof..
From what I can see the XC40 has a small drain on the drivers side and a slightly bigger drain hole on the passenger side just under the bonnet - from my experience in sudden heavy rain when the car is parked at a slight angle.. water appears to sit on the drivers side only to come sloshing over to the passenger side as you pull away - perhaps the drivers side drain can’t cope with the sudden amount of water or the drivers side drain has already been over loaded. I’ve actually heard water slosh across the car and then seen it pour down from the side of the passenger side into the footwell..
The car is kept outside, I keep it clean and try to keep the drains clear of leaves
Has anyone else had this..?
Btnsurfer
Volvo XC40 roofleak
Greetings!
Clearly in allowing water that congregates in the sunroof channel to run down inside the car causing the damage I describe is, to my mind, a design problem a matter which Volvo have yet to respond to. I am presently in correspondence with Volvo about this issue but so far they have tried to deflect the problem onto the dealer who they say should be able to answer these questions but in reality the dealer agrees with me that not only should the water not be allowed to penetrate the car whatever the reason but also given that it does there is no protection afforded to the electrics under the n/s carpets. I will try to update this post once I hear further from Volvo.
Since entering the above I am pleased to say Volvo have accepted some responsibility for this problem and agreed to foot the repair bill. Despite pointing out a number of, what I believe to be design faults, they opted for my contention that no-where in the manual or any other instructions that come with the car does it warn owners that the drain holes at the corners of the sunroof should be regularly checked for blockage. Anyway I applaud Volvo for taking the responsibility for this, in this case, off my shoulders.
https://www.aliexpress.com/item/4000...e52e080e3518-9
Water under drivers seat (right hand).
Greetings!
Their response was that we must have left the windows or sunroof open or waded through high water (neither is the case) and it is an insurance claim. They even warned that the car might be a right off. It is a 2021 model and we have owned it from new for the last 8 months.
Roof drain leaks
Updated info:
The original link I provided has changed. Try this:
Or search for "3pcs Oil truck essential exhaust pipe muffler silicone Exhaust Extension Tube For RC HSP model 1:10 Nitro Car 02026 102009"
Or some of that text . . .
Hello, I was referred to my insurers by the main dealer who refused the claim. I was then referred to the warranty company who said it was wear and tear and also refused the claim. Eventually Volvo agreed to pick up the tab as no-where that I have seen does it state that the drain holes on the sunroof should be regularly checked for blockage. Yours should also be under warranty and thus paid for by Volvo. What I don't understand given this is not a new fault is why Volvo have not ensured this does not happen by firstly sealing the roof against water ingress inside the car (if that happened and water came over the top then at least the owner would have some idea that the drains were blocked) or ensured that if all that is not possible for some reason any water that gets into the footwell is able to get away rather than corrode all the wiring and connections that are situated there.
So over a month, my attic has been leaking. Having had 3 roofers in the problem is still not solved. The first came charged over 500 and we never saw the guy again when it started leaking again emergency plumber. Another came diagnosed it and then did not bother to show up again. 3rd came and tried to fix but still leaks now chasing him up.
There are no missing tiles and no apparent cracks on the apex of the roof. Though saying that that is what the roofers have said and have to take their word on it.
Volvo 2020 xc60 LEAKING SUNROOF
Hi,
I have a 2020 xc60, panoramic sunroof. It was manufactured on 2019, driven as a dealer demo for the first 5k miles, at which point I leased it and then financed once my lease was up. Less than 40k miles. Amazing car. Until last week - when it wouldn’t stay on, nor would the gear shifter work. The emergency brake wouldn’t disengage. Called AAA, had it towed to my local Volvo authorized mechanic. I remember hearing what I thought was water sloshing on the door - then it went away. Or so i thought … until my dealer called and said there was MAJOR water damage. The way have taken the car apart and dried everything, will then review and test the electrical components. I noticed that this model is not included in the class action lawsuit but am furious that, after so much attention was brought to their design flaw, they wouldn’t correct it. I am having my mechanic document all of the findings and was going to then reach out to Volvo for …. Reimbursement? Any suggestions would be appreciated. It seems there are enough people with the same issue - perhaps another lawsuit is in order?
Greetings!
