2018 XC60 T5 intermittant high beam faiure notices
Old Sep 23, 2019 | 06:33 PM
rickb52's Avatar
Default 2018 XC60 T5 intermittant high beam faiure notices
HI all, Been getting intermittent high beam failure notices recently, had dealer investigate and could'nt find anything obvious. Going back in tomorrow, they are going to work with Volvo together and see if they find the culprit. Should be interesting. Makes me wonder what else is going on with the software. I"ll post results in a couple of days. This all started after my first 10k maintenance, Software bug? Well see.
Old Sep 26, 2019 | 09:35 AM
KellyfromVA's Avatar
Sounds like it may be something as simple as a loose electrical connection to the headlight assembly.
Old Sep 26, 2019 | 11:42 AM
rickb52's Avatar
Hello again, The technicians at the dealership, said they found the possible cause, which is an out of tolerance resistor in the headlight (LED) assembly and there was a technical memo that suggested to replace the headlight assemble if that was the scenario. They're doing that today. So we'll see if that is the fix.
Macy517
Apr 27, 2019 05:26 PM
enjuaguese
Jan 1, 2016 04:13 PM
willingrvw
Jul 18, 2015 06:14 PM
mcnallystep98
May 8, 2013 10:54 AM
dljdad
Jan 4, 2010 05:39 PM
