BTN339 H11 Headlight Socket Burned out
Old Jan 29, 2020 | 04:43 PM
Eric Kottke's Avatar
Default BTN339 H11 Headlight Socket Burned out
The passenger side Low Beam Headlight Socket Burned out and I am trying to find a replacement. I have a OSRAM H11 Bulb that I'd like to connect to the socket. I see so many different socket choices, not sure which one to get.
1. Which socket will fit the Light Bulb?
2. How do I connect the new socket to the power source? Do I solder or splice the new wires together or is there a plug to connect to the power source.
Pictures attached.
1. is the driver side connection which works.
2. is the passenger side socket which needs to be replaced and connected to the power source.
Driver side works
Passenger side socket needs to be replaced.
Old Jan 29, 2020 | 07:05 PM
you didn't mention which model year you have but finding a new socket should prove fairly easy since you know the socket number and that you have H11 bulbs. You can find replacement sockets at any of the big box auto parts stores such as Autozone where you'd need to spice in the wire. I'd recommend using solder and a heat shrink insulator - most likely that will come with the replacement socket. As an alternative you can shop at a Volvo dealer parts store and get the genuine Volvo replacement for $5 more. (I use tasca parts since they are here in New England... but there are others. If somebody is going to have a complete wire with connectors on both ends, it would be the dealer store.
Old Jan 29, 2020 | 09:02 PM
Old Jan 30, 2020 | 08:43 AM
looks like it - but also search on parts store web sites like napa online or autozone, you may find something cheaper. I think Tasca had the Genuine Volvo part for $11
Old Feb 2, 2020 | 02:12 PM
Which is positive and negative the A or the B?
Old Feb 2, 2020 | 05:05 PM
does it matter? are the wires color coded? Usually red is + and black is ground. If you are unsure, use your VOM to test the wired socket for which is ground
curtorous
2001-2013 model year XC70
Feb 7, 2015 04:32 PM
Bilster
Oct 29, 2013 10:27 AM
krazylu
Nov 2, 2012 01:31 PM
MaxBoost13brx
Feb 16, 2009 09:07 PM
IKE8120
Dec 21, 2004 12:56 AM
