2004 XC70 MAF sensor reading Problems? Fluctuating Idle
Old Mar 9, 2019 | 06:06 PM
Build's Avatar
Default 2004 XC70 MAF sensor reading Problems? Fluctuating Idle
Hello,
My 2004 XC70 is having fluctuating idle speed (500-1200)/stalling at idle problems. It runs great except at idle.
I have the following codes
P2188 -system too rich
261A - long term trim
262A - long term trim
The throttle body is clean and smoke test showed no vacuum leaks. The spark plugs, coils, filters, etc are new or fairly new.
I checked the signal from the MAF which showed fairly steady 1.58-1.6v at idle (cold), 1.16-1.18v idle (warm). If I accelerate slowly the reading is goes to 2.4v at 2000rpm, 3.2v at 3000rpm. If I accelerate quickly the voltage goes to 0 when I open the throttle, then recovers to shown readings. The car accelerates strongly, no hesitation.
Is this normal for the MAF?
Oddly enough, if I unplug the MAF, I get CEL and code for the MAF but the car idles perfectly smooth, no stalls, runs great. When I plug it back in, it goes back to fluctuating and stalling.
Ideas? Thanks, Jim
gedaggett
Jan 30, 2013 11:59 PM
Plankman
Sep 21, 2012 05:54 PM
Nichals
Dec 2, 2011 05:43 PM
driftin V
May 23, 2006 01:38 AM
