Assembling struts & coil springs
Old May 25, 2023 | 08:49 PM
ionlyski's Avatar
Default Assembling struts & coil springs
2005 xc70-rear struts and coil springs
I don't understand how to orient the spring seats into the strut anchorage. It seems to fit inside fine in every position as you rotate it all the way around. Hard for me to believe it doesn't matter though. There are no obvious notches or anything to indicate where you rotate it to.
Any advice on this?
Arne
Old May 26, 2023 | 10:15 AM
what year? When I did the struts on my 850, the spring ends align the strut to the spring seat and the bolts align the mount. On my Gen 1 S40, there's a hole in the strut and spring seat/mount that aligns at 0 degrees or 20 degrees depending on suspension set up.
Old May 26, 2023 | 02:05 PM
ionlyski's Avatar
Sorry 2005 xc70, edited above.
Old May 27, 2023 | 11:06 AM
ionlyski's Avatar
Thanks. I don't think the 850 is the same then. Yes the spring fits into the spring seat and the strut fits into the coil spring into one and only one position. But then the bottom of the strut piston rotates freely into any orientation to line up with the control arm bolt. Which leaves the spring seat free to rotate around inside the anchorage with no apparent home position.
What am I missing?
Arne
Old Jun 30, 2023 | 08:17 PM
lrock's Avatar
you are supposed to make a witness mark with chalk before disassembly to facilitate installation
Bessarion
Jan 22, 2023 10:59 AM
Zippy83
Feb 9, 2019 10:19 AM
kase6000
Apr 6, 2015 05:56 PM
96850_R
May 17, 2011 09:41 AM
mragan
Mar 21, 2006 12:46 AM
