dying at idle
Old Apr 17, 2008 | 06:45 PM
chihief's Avatar
Default dying at idle
2001 with 100,000 miles. runs fine on hwy. when i come to a stop the rpm's flucuate fromm 1k too 500 rpm and sometimes dies. engine seems to jump. i disconnect the connector to the mass flow valve and the dying seems to get better but it is not solved completely. i need to take it to the neareswt dealership (100 miles away) can i drive it with the connector disconnected or will that cause harm. it was suggested by an ex-volvo tech. that the throttle body may need replacing. ( i drove 20 miles home disconnected and my gas mileage went from 23.6 to 33.2) if i can get a reply tonight before i make the journey to the dealership tomorrow it would be greatly appreciated.
Old Apr 17, 2008 | 07:16 PM
Default RE: dying at idle
If it were me I would try cleaning the throttle body first.
But it isn't an easy task on yours.
It is up under the intake manifold.
Old Dec 30, 2008 | 10:10 AM
nuf's Avatar
nuf
i have the same problem.. were you able to fix it....
Old Dec 31, 2008 | 08:02 AM
Psaboic's Avatar
Try cleaning the throttle body, then try cleaning the MAF and see if that helps.
peerson89
1998-2000 model year V70
Sep 24, 2014 08:59 PM
MilesDunis
2001-2013 model year V70
Apr 5, 2013 06:32 PM
hawkreborn
Mar 7, 2013 09:33 AM
youngvolvoowner
Aug 31, 2008 10:28 PM
funsox1
Nov 23, 2003 03:45 AM
