Fair estimate for timing belt
Old Nov 2, 2011 | 09:22 AM
bulldog's Avatar
Default Fair estimate for timing belt
On a 98 xc70awd. With and without water pump replacement. Got one bid from dealer but need some more data from you experts out there.
Old Nov 2, 2011 | 05:17 PM
VTBricked's Avatar
3-4 hours labor max plus parts
Old Nov 3, 2011 | 06:30 AM
bulldog's Avatar
So...$$$ estimate?
Old Nov 3, 2011 | 09:02 AM
SVolvoD4's Avatar
Depends on the area you are in and who does it for you. I would suggest calling a few different shops in your area to get an estimate, the dealer is going to be more expensive than a private shop. It will probably be around $400.
Old Nov 3, 2011 | 09:26 AM
bulldog's Avatar
Thanks, what I was looking for. Haven't had it done in long time and wanted some recent experiences. Got a quote for $700 and didn't include water pump.
Old Nov 3, 2011 | 09:29 AM
SVolvoD4's Avatar
That sounds a little high, but I've never done it at a dealer, I bet there is a good reputable shop in your area that will do it for a few hundred less. Good luck to you, and let us know how much it ended up being and where you went, thanks.
Old Nov 3, 2011 | 09:41 AM
bigsurvolvo's Avatar
I got mine done for $300 w/ parts, no wp
Old Nov 3, 2011 | 10:37 AM
bulldog's Avatar
$300 total including parts!???
Old Nov 3, 2011 | 11:51 AM
I've befriended my local Indy, so he helps me out. I bought the core for cost. And he is a guru! Knows all the little secrets.
Old Nov 11, 2011 | 10:57 AM
bulldog's Avatar
My final bill was $880 but that included a bent sway bar replaced, rear seals leaking replaced, along with the timing belt.
Old Nov 11, 2011 | 03:19 PM
SVolvoD4's Avatar
Was that from a dealer then?
Old Nov 14, 2011 | 09:57 AM
bulldog's Avatar
Yes, and it was less than from an indie service station. Go figure. I prepped the dealer with "want to know what's happening with oil leak and any/everything else" before decide what next". Dealer came back with the rear seals and timing belt, and stated that I should expect 400-500k miles out of the car. We will see. Quizzed him on awd drivetrain and came back with the same. Said the awd failure was really rare. This dealer works on a good number of high mileage awd v70s, so there appears to be some real experience behind that. We will see!
Old Nov 15, 2011 | 02:02 PM
SVolvoD4's Avatar
Good deal, well good luck...you'll make it
Old Nov 16, 2011 | 10:47 AM
bulldog's Avatar
Thanks. Like me it has a few creaks and groans but I think the xc is likely to go 350k anyway.
fred in florida
Aug 16, 2014 03:46 PM
S80_Pilot
Dec 18, 2011 03:29 AM
Aopocetx
Dec 15, 2008 12:43 PM
TravlAndy
Nov 11, 2007 06:15 AM
dancewithmike
May 25, 2007 06:40 AM
