Front Suspension advice... Need help!
Old Sep 16, 2010 | 09:06 PM
generic1's Avatar
Default Front Suspension advice... Need help!
I am replacing the front shock/struts on my 99 XC...
I would love some recommendations for front shocks.. Factory Sachs or Biltsteins? Are there different part #'s for the V70 & the XC?
Also, I am wanting to fix the clunking going over bumps.. Will I need to install new upper spring seats? Shock Mount bearings?
I appreciate your help...
Old Sep 16, 2010 | 09:47 PM
family XC70's Avatar
Your springs are probably OK unless you live somewhere that salts the roads frequently or they are cracked or broken. The clunking is most liking coming from the big rubber bushing underneath your strut mount bearing being worn out. If you are going to take it apart and compress your springs then I would recommend replacing all of the top mount parts. You may also want to look at your ball joints also while you have it apart. I put Sachs struts on mine. Be sure to use a quality spring compressor if you have never done this.
Old Sep 17, 2010 | 09:43 AM
generic1's Avatar
Ok... I am looking at replacing:
- Shock/strut
- Upper spring seat
- Shock mount bearing
- strut bump stop
Is this overkill or recommended? Also, needing to know if the part # on shocks will be same for the v70 awd, and the XC 70? With the raised suspension of the XC, is it a different part? Thx
Old Sep 18, 2010 | 07:39 AM
I would recommend changing all of that. I also changed my lower control arms and ball joints when I did it. As for the top parts, you are right there at them and you have to compress the springs to do any of that work so I would just get it all done while you are at it. I am not going to be any help with part numbers. call FCP Groton and ask a tech. Good luck!
Old Sep 20, 2010 | 08:25 AM
generic1's Avatar
thanks, I really appreciate the advice and help!
Old Sep 20, 2010 | 08:31 PM
Your welcome, good luck with it.
Old Oct 9, 2010 | 05:56 AM
aneudy1986's Avatar
part# 554 046= sachs
BluenYellow
Suspension
Aug 5, 2014 05:35 PM
msimpsonnj
Jan 19, 2014 03:06 PM
NightSailor
Aug 20, 2011 03:59 PM
chrispol
Dec 8, 2010 05:37 AM
litehwk356
Oct 4, 2008 08:20 PM
