Going to clean crankcase vent sys. are these good directions?
Old Oct 16, 2008 | 08:14 PM
Timmy1's Avatar
Default Going to clean crankcase vent sys. are these good directions?
http://www.v70xc.com/resources/how-t...g%20Method.pdf
1999 V70XC turbo
Also need throttle body cleaning directions.
Thanks!
Old Oct 16, 2008 | 09:39 PM
Default RE: Going to clean crankcase vent sys. are these good directions?
If it were me for going through that I would just pull the intake and replace the ventbox and clean all the hoses that way.
You can also get to those hoses if you remove the P/S from the bracket without unhooking the P/S lines.
To be honest when I have to do it I never remove anything. I have long needle nose pliers and slide the hose off the fitting then blow through the hose. Then use a small piece of heavy wire and clean the banjo fitting with it.
03CJ31
Mar 29, 2012 10:39 AM
madymo3d
Sep 22, 2009 01:08 PM
emanz1
Jun 28, 2009 10:11 PM
BlazeS70
May 22, 2009 04:53 AM
GearHeadKS
Sep 10, 2007 05:56 PM
