Headlight Wiper Motor
Old Feb 22, 2010 | 06:02 PM
daharleyrdr's Avatar
Default Headlight Wiper Motor
I have a 2000 Xc and the drivers side wiper sometimes when used will stay in the 12O clock position. I have to check the tightness of the 10mm nut as I saw posted, but noticed that I was able to return the wiper manually to the rest position without too much resistance from the motor, as opposed to the pass side one that is working perfectly cant move that one is this good or bad? Thanks Bill
Old Feb 22, 2010 | 09:38 PM
The motors always go bad on these cars. On my own cars I unplug them as soon as I buy them.
Old Feb 23, 2010 | 09:53 AM
Smile Headlight Wiper Motor
Tech
Thanks I may just do that I think theyre unnessecery I mean when its icy or snowy dont bother, I like the newer volvos just a stream of washer fluid is used on the headlights no wipers!
How do I unplug them where is the plug located and I thought I read somewhere to just tie the washer hoses to each headlight in a knot to prevent fluid loss when using the windshield washer? Its a 2000 V70 XC Thanks Bill
Old Feb 23, 2010 | 09:09 PM
There should be an Orange color plug around the headlight area. That should be the plug for the wipers. I just left my hoses alone.
Old Feb 24, 2010 | 06:43 AM
Thumbs up Headlight Wiper Motors
Tech
Thanks Ill check it out later today and let you know how I make out.
Thanks again Bill
Old Feb 24, 2010 | 03:21 PM
Wink Headlight Wiper Motor
Tech
Thanks I did find the plugs one on each side just as you said. I didnt unplug them yet I tightened the 9mm nuts on the end of the motor shaft on the wiper arm as wsas suggested by somone else, they were loose and it seems to be working fine. Thanks to you I have a backup plan, unplug em if they give me any more problems.
Thanks Bill
Old Feb 24, 2010 | 09:05 PM
Glad they are working for now. I am not sure for how long though. LOL
dpsam
May 2, 2009 02:02 AM
mpoulin2002
Nov 3, 2008 01:59 PM
Psaboic
Apr 29, 2007 02:59 PM
Ward850T
Apr 25, 2007 09:50 PM
