2003 XC90 T6 AWD is billowing white smoke from exhaust!!
Old Mar 14, 2014 | 10:26 PM
cdewitt8680's Avatar
Default 2003 XC90 T6 AWD is billowing white smoke from exhaust!!
Yesterday my XC90 began blowing thick white smoke from the exhaust. The oil is not low and it has plenty of coolant. At no point did the truck overheat either. I pulled 10 codes which were all for cylinder misfire. My father thinks it may be the EGR valve. Anyone have this problem before? Help!!!
Old Mar 17, 2014 | 01:01 PM
schumicat's Avatar
white smoke can mean engine is burning coolant. i would check for oil in coolant and vice versa.
Old Mar 25, 2015 | 09:15 PM
tobinsmith's Avatar
The trans has a cooling line that sometimes allows coolant to bleed into it. Its the beginning of problems if you don't fix it right away.
casperskewl
Apr 30, 2021 05:31 PM
Popeye75bm
Nov 18, 2013 09:26 AM
rspi
Aug 14, 2013 08:05 PM
2003xc90
Sep 11, 2012 03:38 PM
oneelkarcher
Feb 12, 2012 06:17 PM
