Ac
Old May 15, 2019 | 11:32 PM
Chuks_bobby's Avatar
Default Ac
My Ac is cold on one side and hot on the other side. I have changed the compressor and valve yet same outcome
Old May 16, 2019 | 07:39 AM
are you referring to the lines going to/from the compressor or the air coming out of the dash vents?
The lines to/from the compressor should be warm and cold. The way AC systems work is the line from the compressor to the condensor has the refridgerant that was just compressed which heats it up, and its the job of the condensor to extract the heat (ie like a radiator). As the refridgerant flows into the evaporator its expanded which cools it off so the evaporator extracts the cold (the reverse of a radiator) to chill the cabin air. The return line from the evaporator to the compressor still has the cool expanded refridgerant so I'd that line to be cold to the touch. If you have a cold return line (to the point of frosting up) then your AC is working normally.
pampadori
Jul 9, 2019 09:12 AM
MarkInTexas
Jul 1, 2017 01:24 PM
Spyros
Aug 18, 2014 02:18 PM
kingnai
Jun 25, 2009 07:02 PM
Systek
Oct 15, 2007 08:08 AM
