Cooling fan only runs on high after replacement
Old Jul 2, 2019 | 12:18 PM
Stillwellsgarage's Avatar
Default Cooling fan only runs on high after replacement
Just replaced the blower motor and resistor, now it only blows on high and the control panel lights don't work. The parts are all in working order, tested fine. Where do I go from here?
Old Jul 2, 2019 | 01:12 PM
cooling fan as in the radiator fan or the blower motor for the interior. If your interior blower is only running at full speed, the ballast resistor or connectors to the ballast are not shunting current through the resistor. The blower will run at full speed because the resistor is bypassed.
unobtain
Dec 3, 2017 03:06 PM
smshnick
Sep 29, 2016 02:30 PM
autoxray
Dec 31, 2008 11:06 AM
je850
Jun 20, 2008 08:32 AM
maddox
Aug 5, 2006 01:25 PM
