High beam is not working (just one side) on xc90 D5 from 2008
Old Oct 15, 2017 | 08:12 AM
Karen Hovhannisyan's Avatar
Default High beam is not working (just one side) on xc90 D5 from 2008
The high beam on the passanger side is not working, change the bulb, still the same. Where to check next?
THanks in advance!
Old Nov 25, 2023 | 11:40 AM
williamthrilliam's Avatar
Hi @Karen Hovhannisyan did you ever figure this out? I have the exact same problem on my 2014 XC90. I have replaced the fuses, bulbs, and the turn signal stalk! I still only have brights that stay on on the driver's side, the passenger side will not stay on. If I flash them when the light switch is on the 9 o'clock position, both brights turn on! So weird!
Old Dec 9, 2023 | 09:46 PM
hot9000's Avatar
I had to replace with this
Amazon Amazon
not the high beam bulb which is still working. Hope it helps.
Volvo_magic
Dec 2, 2021 08:49 PM
rest05
Feb 19, 2018 05:54 AM
19woodstock50
Sep 3, 2017 12:28 PM
wlandymore
Mar 2, 2013 08:43 AM
pbrengel
Feb 18, 2011 07:20 PM
