PS fluid leaking?..
Old Apr 14, 2008 | 09:29 AM
m1964's Avatar
Default PS fluid leaking?..
While ago I noted dark brown fluid on top of transmission, see my post -https://volvoforums.com/m_83407/tm.htm.
At the time I thought it was engine oil. Recently I noted Rack-and-pinion becoming noisy -last week I brought XC90 for 30K service, and told them about steering noise-I was told, that "teck topped-off the PS fluid, and it fixed the problem".
When I asked if they found any leaks, I was told "No, but they tightened up all the connections"..
I wonder if this dark fluid on top of trannyis PS fluid, and where it is coming from?
Any one knows?
Thanks a lot.
PS
I will post if I find out...
Old Apr 20, 2008 | 08:18 AM
dpsa's Avatar
Default RE: PS fluid leaking?..
PS is not usually dark. I would inspect other areas above or near this fluid for another cause.
Old Apr 20, 2008 | 08:54 AM
JPN's Avatar
JPN
Many modern cars seem to use ATF for PWS. They are usually clear red but check with you owner's manual to see what fluid is required.
JPN
ludeless
Nov 18, 2023 07:51 AM
yineyes
Jul 11, 2007 11:35 AM
Majki
Jun 10, 2007 12:37 PM
97volvo850
Aug 27, 2006 12:11 PM
Bklyn
Jan 11, 2006 12:28 AM
