Rem Help fuse # 23
Old Jan 5, 2015 | 05:21 PM
dayt82's Avatar
Default Rem Help fuse # 23
HI I'm having some problems with my 2007 xc90 4.4 L V8 AWD.
I was not getting power to fuse #23 to power the DEM so I removed the REM and sent it to XeMODeX to get the REM Repaired . XeMODeX benched tested the REM and they said the part was ok. Than they sent it back to me, I was wondering why the REM benched tested ok but when I reinstalled the REM I still don't have power to fuse #23.
Thanks for your help!
Old Jan 5, 2015 | 07:55 PM
damien360's Avatar
Is the fuse blown?
Old Jan 6, 2015 | 08:51 AM
dayt82's Avatar
No the fuse is good.
Thanks for you help
Old Jan 6, 2015 | 09:35 AM
ES6T's Avatar
Check fuse 27
Old Jan 6, 2015 | 10:44 AM
dayt82's Avatar
Ok will do !
Old Jan 6, 2015 | 06:08 PM
gstallons's Avatar
Default fuses
Originally Posted by dayt82
Ok will do !
There is no law that says you cannot check all fuses . It may save you more sorrow ?
Old Jan 6, 2015 | 07:07 PM
ES6T's Avatar
Checking all fuses is unnecessary. No point in checking a bunch of fuses that have nothing to do with the circuit.
Old Jan 7, 2015 | 06:37 AM
dayt82's Avatar
Hi I checked the REM and I am getting 14 volts dc from the battery, but I'm not getting power to any of the fuses. I checked every fuse for continuity and they all checked out good.
Old Jan 7, 2015 | 07:19 AM
gstallons's Avatar
Default un necessary !
In 40 years of working on automobiles I have found it thorough to check all fuses while I am checking one fuse. You might find a bad fuse that feeds the circuit you are trying to repair or repair a device you did not know was bad .
Old Jan 7, 2015 | 07:21 AM
ES6T's Avatar
So none of the fuses have power? How are you checking?
Old Jan 7, 2015 | 08:52 AM
gstallons's Avatar
If you want to have a conversation , we can have a conversation . If you want to argue , find someone else .
I am suggesting to the OP it will or might help him to check all the fuses in the fuse panel to help diagnose his problem.
Old Jan 7, 2015 | 09:20 AM
ES6T's Avatar
Thanks, but I wasn't talking to you.
Old Jan 7, 2015 | 10:29 AM
gstallons's Avatar
my apologies .
Geoff813
May 20, 2021 02:31 PM
Raniz
1998-2000 model year V70
Jul 5, 2013 05:35 AM
deeno77
Apr 18, 2013 07:11 AM
mercury 100
Jan 19, 2009 07:50 AM
tzracer
Nov 29, 2007 06:09 PM
