Trans. fluid check???
Old Jun 8, 2014 | 01:36 PM
dodgerdogg's Avatar
Default Trans. fluid check???
Where is the trans. dip stick?? how do you check the fluid level??
Old Jun 8, 2014 | 02:18 PM
pkrface's Avatar
Small yellow dipstick below the radiator hose on the drivers side front of the trans housing. Tough to get to and see. Level ground at operating temp with engine running in park.
Old Jun 9, 2014 | 08:44 AM
dodgerdogg's Avatar
Thanks again pkrface, sounds like you are a wealth of knowledge. Glad people like you are on here to guide us newbees!
Old Jun 9, 2014 | 08:49 AM
dodgerdogg's Avatar
please tell me there is a way to fill it other than that hole!!!!
Old Jun 9, 2014 | 08:14 PM
pkrface's Avatar
No, and whatever you do, do not take out the bolt on top of the trans case thinking it is a fill spot! Use a funnel with a flex tube attached. It's a little slow going, but not too bad. IPD has the funnel if you can't find it anywhere else and is a great resource for Volvo owners.
Eric's Hot Rod Shop
Jul 14, 2011 08:26 AM
VTBricked
Nov 21, 2009 07:50 AM
ruister
Oct 9, 2006 09:13 PM
nitewitch55
Jul 26, 2006 10:18 PM
WickedPete
Feb 15, 2006 08:43 PM
