trouble setting up my equalizers
Old Jun 27, 2011 | 12:43 PM
04XC90T6AWD's Avatar
Default trouble setting up my equalizers
Hi,
I need a bit of help setting up my equalizers properly i seem to be having a bit of trouble with it i never was good with the audio type things mechanics is more my speed.... anyway I fiddled with my Eq settings in bumper to bumper traffic for about 2 hours and only managed to get the sound quality to sound worse! I just dont know how to tweat these settings properly what setups do some of you guys use? I listen to mostly country and classic rock what type of setup would you recommend for those genres? any help is appreciated im sick of having a high end sound system and having it sound all out of whack
Old Jul 11, 2011 | 09:31 PM
sweedehorses4me's Avatar
I've don't have any upgrades on the sound system on my XC90, so if you do - it might be different. My system has a basic "bass" and "treble" control accessible from the big dial on the right alongside of the fade and balance settings. Then, mine has more detailed EQ within the "menu" and has separate EQ settings for both the front and rear speakers. If yours is like this, here are some tips..
On EQ within the menu, I set both the front and rear EQ's to the same settings. For the 50hz band, I left it at 0 (the middle), for the 200hz band I pushed it up 4 notches or so. For 1khz, I put it at 3 notches. 3khz at 2 notches, 12khz at 1 notch. I then went to the basic EQ through the dial and boosted the bass almost all the way up and left the treble in the middle.
I find this setting to sound good - hope this helps!
Old Jul 12, 2011 | 01:59 AM
ShowTek's Avatar
But for someone like me, who listens mostly to dubstep/hardstyle, +3 on bass and +1 to rear.
1200watt's flowing from the trunk sure does rattle a few panels.
Old Jul 12, 2011 | 10:36 AM
yep mine is the same way i have the premium package so mine are Harmon kardons but same setup
Old Jul 13, 2011 | 07:25 AM
Cool - hope it works for you. Generally, you'll be able to tweak a good bit with that 5 band EQ in the menu. A basic guide to using those bands is that 50hz will add depth, 200hz should fill out the sound and add some punch to the low end. 1khz will add bite, but typically is not a pleasing frequency. Kind of the same for 3khz.. adds some high-mid detail, but usually not a freq that I boost, although it seems to not be too harsh in the XC90. The 12khz is pretty high, so it'll add sheen and crispness.
Without using the menu EQ and just boosting the bass on the dial, my XC90 had a plush low end without much punch. The mids and highs were ok, but punch in the low end was lacking - but the menu EQ seems to allow for me to kind of make up for that. My XC90 has the premium package and the versatility package.
My wife bought a 2007 S60 before we were married.. any idea on how to see which packages it has?
Thanks!
cederrowe
Oct 31, 2008 07:28 AM
micah360
May 28, 2008 04:14 PM
dukesdbomb
Feb 10, 2007 10:28 AM
tenpiloto
Nov 27, 2005 09:02 PM
oalsa
Nov 16, 2005 10:45 PM
