Washer motor running, high beams on, key off. Help?
Old Jan 18, 2025 | 12:36 PM
bronson75's Avatar
Default Washer motor running, high beams on, key off. Help?
Heard a strange whining sound outside the other evening, went out and the high beams on my wife's XC90 were on and the washer pump was running/howling. The car was locked, she had been home for a couple of hours. Strong pungent smell inside the car, I assume the pump had been running, pumped all of the washer fluid out, and started burning the motor up when it ran dry. I could not turn off the lights or get the pump to shut off, I had to disconnect the battery.
She has gotten the DSTC Spin Control Off message recently, from searching, it seems like her steering angle sensor is failing. Should I assume that the high beams/washer pump running are also a symptom of failing electronics in the steering column?
I let the car sit for about a week, reconnected the battery yesterday and the symptoms were still present.
Old Jan 18, 2025 | 03:33 PM
A good first step would be to scan all the control units with a compatible scan tool. Looking for relevant self diagnostic codes. Since the switches for both of those malfunctioning items are connected to the steering column module - that might be a hint. That module under the steering wheel is not a common replacement item. The contact reel is, but that part should not cause washer and high beam problems. If you don't have immediate access to a compatible scan tool, How about simply removing the ts and wiper switch and seeing what happens?
Sometimes water gets into the CEM and causes strange problems also.
reknoppow
Dec 3, 2021 01:17 PM
BackCountry
May 9, 2021 06:02 AM
twn22
Volvo C30
Jan 15, 2016 04:33 PM
Phil 850
Jul 24, 2012 10:55 PM
hairyg
Mar 15, 2009 08:04 AM
