Windshield Washer Pump
Old Dec 2, 2021 | 10:46 PM
reknoppow's Avatar
Default Windshield Washer Pump
The washer on my 240 does not work. I traced the wiring and find I get voltage at the connector. I also find the motor shows resistance but it does not pump. I will probably replace it but wonder if there is a quick fix.
Old Dec 3, 2021 | 09:50 AM
lev's Avatar
lev
You need a new motor... quick fix? May be you can rebuild it... or get a used one.
Old Dec 3, 2021 | 11:04 AM
The pump portion on some of them gets clogged, you can remove the motor, apply 12v to test it and clean the pump portion if needed.
Old Dec 3, 2021 | 01:17 PM
reknoppow's Avatar
Thanks, I might try that. It depends on what a replacement costs, if not expensive I will just replace it.
BackCountry
May 9, 2021 06:02 AM
samimc
Mar 2, 2011 08:10 PM
cobra66
Sep 6, 2009 09:11 AM
hairyg
Mar 15, 2009 08:04 AM
Moon
Dec 10, 2007 09:01 PM
